MXI-3 not detected with a PXI-1045
I had a MXI-3 card in a host computer attached to a PXI-1010 chassis. The MXI-3 card was detected and all cards in the 1010 chassis were detected as well.
Now I've moved the MXI-3 card to a 1045 chassis and now the card and chassis are no longer detected.
Yes, both the power and link lights are lit, but I see no blinking of the rx and tx lights like I did with the 1010 chassis.
The MXI-3 card was plugged in slot 1 of both chassis.
Is there any reason MXI-4 shouldn't work in the 1045 chassis?
Mike
(3,637 Views)
Of course, I meant:
Is there any reason why MXI-3 won't work in a PXI-1045, but will in a PXI-1010?
(3,628 Views)
It's working now.
Thanks everybody for the quick responses.
Oh wait. I didn't get any.. 😞
(3,616 Views)
We are glad to hear that you are up and running now.
Did you have to re-adjust the MXI-3 cable?
Christian A
(3,599 Views)
No, I brought over the 1010 chassis from my desk, removed the MXI-3 w/cable attached to the 1045 and plugged it into the 1010. The remote PC came up just fine, recognizing all cards in the chassis.
I then removed the MXI-3 from the1010 and plugged it back into the 1045. Powered up the 1045 and booted up the PC and the MXI-3 was recognized.
I'm not sure what the problem was, but I've removed the MXI-3 quite a few times from the 1045 and haven't had a problem since.
Now i have a VCI compiler problem. Maybe another thread....
Mike
Message Edited by mikie on 04-28-2008 01:05 PM
(3,594 Views)
