Measure voltage continuously for 2 hrs or more
Hello
Im trying to do a sensor setup, where I need to measure the voltage continuously. Im supplying current 10E-9A using Keithley 220 current source and measuring voltage using Keithley 6514 electrometer. Everything works fine until time runs out and reset the measurement. Once it reset there is a spike in data which is not true. So I would like to continue collecting data for atleast 2hrs without resetting Keithly 6514 electrometer. I have attached the file I have been using.
Please do let me know if this can be done.
(2,861 Views)
Why not move all of that initiation outside of your (Timed!) loop and just run the Read Block inside?
Keithley 6514 LV 8.0.lvlib_Keithley 6514 Meas Voltage Example WORKING_BD.png
GCentral
(2,814 Views)
