sbRIO 9637 RS232 communication with Amulet Touchscreen Display - Checksum Error
Hej there,
hopefully I am posting on the correct board for my topic!
I am currently facing some problems with the serial connection of a sbRIO 9637 system with an Amulet Touchscreen Display. Therefore I am hoping to get some advices on how to establish the serial communication between both devices.
At that moment I did the following: First I got started by using the example code of Amulet Technologies API to get a first impression on how to work with the Touchscreen Display. That worked fine for my laptop. On my laptop I am using an RS232 USB-adapter to attach the Display to my computer (cables are self-build). All example Vis from Amulet work fine and I do not have anything to complain about.
Second I wanted to do the same with my Desktop Computer which has an internal serial port. There I am always getting a Checksum Error on the example Vis on the first serial read after a few seconds. I tried around by the configuration settings of the COM-port but I have not managed to get it to work without any errors.
Third I established a connection between the sbRIO 9637 and my laptop (with USB-serial converter) to test the self build cables which I want to use between the sbRIO 9637 and the Amulet Display. Therefore I used the NI Example continuous serial read/write which I run on my laptop and which I put on the sbRIO 9637 – just to test if both is working: can I sent a string from my sbRIO and receive it over the serial connection on my laptop and vice versa. That worked as well fine for me.
Finally I wanted to connect the sbRIO with the Amulet display and test it with the examples provided by Amulet Technologies. Unfortunately I directly get a checksum error on the first serial read.
I got the impression that this is the same problem as I am facing with the build in COM-port on my desktop pc, but I do not know how to troubleshoot on. Actually the only thing I want to do with my sbRIO  is to read a value of the internal RAM of the Amulet display.
I feel all is related to the configuration of the serial port on the sbRIO/Desktop pc and on the Amulet Display. Do you have any advices how to go on to get it to work?
We are using LabVIEW 2017, I have installed the latest Amulet API 1.0.0.30. On my laptop I am running Windows 10 and on my desktop Windows 7. On the sbRIO I am using the Instr2-port but the console is also not enabled, so I could also use Instr1-port of the sbRIO.
If you need further details please do not hesitate to ask for them.
Thank you for your help and best regards,
Florian
(3,751 Views)
I'm going to hazard a guess that might well be wrong, so apologies if you've already checked this...
It seems that when you use a converter (to USB) you have no problems, whilst the cable gives you issues without a converter. It might be that your USB converter is switching the TX and RX signals for you. If you have a "null-modem" connector, you can try placing that in line and see if it helps.
If you don't have a suitable connector (or a crossover cable/straight cable, whichever is the opposite of your current cable) then you can just manually wire them - switch TX and RX using jumper pins or something to test it without needing to cut any wires up.
Second guess would be that the USB converter shorts some pins together to ensure that handshaking is effectively a no-op - it always succeeds. It might be that your cable has real lines for CTS, RTS and so on, and that these are being checked by one end but not used by the other?
GCentral
(3,663 Views)
