03-02-2009 08:41 AM
03-02-2009 08:42 AM
Is there a permanent fix for this issue now?
thanks!
03-03-2009 09:53 AM
03-03-2009 02:21 PM
Hello:
Please check which version of NI-488.2 you have installed. This issue should have been resolved as of version 2.6 of the NI-488.2 driver. The newest version, 2.7, is available here.
If you have version 2.6 or later, I would be more than happy to investigate the behavior you are seeing.
03-03-2009 03:19 PM
I'm using NI 488.2 v2.52. I'm unable to upgrade my development machine due to production machines needing to be upgraded first or else my application build may bust.
But thank you for letting us know the problem should be resolved in newer versions.
