‎01-15-2002 01:31 PM
‎01-22-2002 03:06 AM
‎01-22-2002 03:44 AM
‎05-09-2016 06:17 PM
Alison,
Would you be able to clarify a bit on what you mean by "computer not getting the waveforms"? You mention using LabVIEW with your instrument driver, which commands are you using?
I'd also recommend the following steps:
1. select your GPIB port in MAX, scan for instrument, then select your device
2. open up a GPIB control panel (similar to VISA) or the GPIB Interactive Control interface from your start menu on your computer (under NI-488.2)
3. send a *IDN? query
you should recieve information about your instrument, confirming (on top of your device showing up in MAX) that your device is communicating properly.
