01-31-2007 07:42 AM
02-01-2007
05:03 PM
- last edited on
03-09-2026
08:39 PM
by
Content Cleaner
Hi nonee,
Is the new computer considerably faster than the old computer? If so, you may need to adjust the bus timing of your application. Are you receiving any errors when the program hangs, and if so, what number/type? Also, what version of the 488.2 driver are you now using and is the behavior the same with all the version of LabVIEW you have tried (sorry for another question, but what versions did you try on?)?
Hope this helps!
Adam W
Applications Engineering
02-07-2007 10:11 PM
