Missing interfaces in Visa.net 17.0 ?
I am trying to use NationalInstruments.Visa .Net assembly (version 17.0.0) in a Visual Studio 2017 project. When I add the reference to the assembly in my project, I can see the classes (GpibSession, SerialSession, etc) in the object explorer, but it seems that some interface definition are missing: IVisaSession, IMessageBasedSession, etc.
When I use the older assembly "VisaNS" (version 13.0.45.167), everything is fine.
Is there another reference to add to the project ?
(2,928 Views)
Accepted by topic author slefoll
I finally found out what was missing: you need to reference assembly "Ivi.Visa" to use the new "IVI-compliant NI-VISA .NET API", as documented here:
https://www.ni.com/en/support/documentation/supplemental/15/national-instruments-visa--net-library.h...
(2,888 Views)
