Problem with pxie 4139
Hi all
I have a problem with my SMU (NI PXIe-4139), I was programing under LabVIEW normally then I have an error that says  "Internal hardware error occurred in Power_Supply hardware. Please contact National Instruments Support.
Component Name: Nimxslu Proxy
File Name: This is NOT an error in nimxslu. See nimxsl/TStatus2KernelProxyWrapper. cpp For information Line Number: 290  "And when I checked out on MAX I found another NI PXIe-4139 device that added as shown in the photo I'm joining and I have this error that appears " status Code:-235140
Internal hardware Error occurred in Power_Supply hardware. Please contact National Instruments Support.  "So do you have any idea what's going on?
(3,049 Views)
Hello Jazz94,
I think you need to upgrade your NI DCPower to a more recent version because of this bugfix:
https://www.ni.com/en/support/documentation/bugs/17/ni-dcpower-14-1-2-bug-fixes.html
You can find a more suitable version (after 14.1.2 ) here:
https://www.ni.com/en/support/downloads/drivers/download.ni-dcpower.html
I hope this helps! Have a good day,
Regards
Corentin
Application Engineer - National Instruments - France
(3,010 Views)
