Modbus CRC16 generation question
Dear guys
        I have a problem in the edit the CRC16 code,i can't get the CRC16 checksum is same as the correct command list showing.pls help to have a look about my Vi,if have a bug or no attention point,thanks a lot.attached my vi,fyi.
(10,018 Views)
I want to send the string"01 03 00 00 00 08",then generate a CRC "0C 44",but the result is not my attention.
(10,014 Views)
To start with your second post. The ModBus CRC of the command you give is not 0x0C44 but it is 0x440C
In you program you convert a string into a byte array. If you convert the slave address '01' as a string into a byte array you will get two bytes 0x30 and 0x31. The are ascii character and what you need is a single byte with the value of 0x01.
If change your VI.
Kees
(10,002 Views)
Accepted by xiaozhao
Dear Kees,
        Thanks a lot.i got it.i use labview 13.0 version,i can't open you VI,but i have change my vi,now it can meet the result when swap the low 8bit and high 8bit,thanks a lot again.i'm misguided by the meter communication spec.
(9,994 Views)
To be complete. Here is the LV 2013 version.
Kees
(9,953 Views)
(*bump*) I have attached your code with the incorporated byte swap for version 2018. Kees' version appended two zero-value bytes that made the Modbus CRC calculation invalid, and your approach seemed more straightforward.
(9,109 Views)
