Modbus RTU electronic fan speed controller with RJ45
Hello
I am trying to control a motor via Modbus RTU.
My computer will be master and the motor driver will be slave.
The connection diagram in the instruction manual is as follows:
Since there are only 2 wires to connect for Modbus.
Is it possible to modify a simple network cable (rj45 connector) and tell LabView to send the Modbus data over those 2 wires?
Instruction manual of the motor controller can be found at the bottom.
Maybe i understand modbus completely wrong but please enlighten me 🙂
Thanks in advance.
(4,260 Views)
Okay so i've learnt that because of the OSI 7 layer system i can't just "tell" labview to do this.
I need a converter.
I'm planning on using USB instead of a network cable.
How do i do this? Can i search for the motor driver in NI MAX once it is connected?
And what Modbus package can i use best in this situation?
I've already installed GmodBus over serial line from SAPHIR and
NI Modbus library.
(4,207 Views)
If you have no hardware,
There is this forum:
https://forums.ni.com/t5/Industrial-Communications/labiew-lib-for-modbus-over-RS485-over-USB/td-p/12...
That recommends this: https://www.ni.com/en/shop/hardware/serial/model-usb-485
Do you have the sufficient budget for that?
(4,201 Views)
