Modbus related hardware and software
I use a fuel cell which has ModBus protocol and its output is RS485 and I have a weather station which is also uses ModBus protocol but its output is RS232. I want to gather all the data they have and transfer it to a laptop which has labview. In terms of hardware what do I need to connect fuel cell’s and weather station’s RS outputs to laptop? Is a simple serial to usb or serial to ethernet converter enough? Lastly, in terms of software which module should I have?
Thank you
(4,109 Views)
the software is the same, you need an rs232 to rs485 converter for the special module. It is only a hardware difference.
greetings from the Netherlands
(4,103 Views)
Albert thanks for the reply.
I think my question is not clear, sorry for that.
1- What I want to know is "How can I connect fuel cell to my laptop and read the values in LABVIEW which fuel cell is already measuring so I don't need to buy extra sensors?" ,
I contacted fuel cell's manufacturer, they say it uses Modbus and has a RS485 output and I have commands.
2-  Because laptop does not have serial connection I need to buy an usb to serial or PCMCIA to serial converter. Can a simple converter do this work or should I have to buy this; https://www.ni.com/en-us/support/model.usb-232-2.html
3- And which one will be more reliable? Converting Rs485 to Rs232 or converting Rs232 to Rs485?
(4,084 Views)
(4,070 Views)
Hi
If you are already reading data in LabVIEW from one module, you probably have already an interface.
RS485 is in fact a bus interface so maybe you can connect both instruments.
(930 Views)
