NI-488.2 for RHEL 7.9 (64-bit) Installation Help
All,
[ RHEL 7.9 ]
[ Kernel: 3.10.0-1160.81.1.el7.x86_64 ]
After following these instructions to install NI-488.2 v.21.5: https://www.ni.com/en-us/support/documentation/supplemental/18/downloading-and-installing-ni-driver-... it seemed as though the installation went smoothly but I seem to be missing libgpibapi.so as well as several other folders I expected to be in /usr/local/natinst. Looking at previous posts, it looks like libgpibapi.so has only ever been designed for 32-bit use. Has this been changed with later versions? Any help is greatly appreciated!
(1,107 Views)
Hello, I know this post is over a year old, but did you ever come to a resolution with this? I am having a similar issue on a rhel 7.9 64-bit system where it seems everything installed, but previously written very old code for a 32-bit system is not finding the libgpibapi.so. Just wondering what you may have found.
(598 Views)
