Hi All,
I am trying to communicate with a non NI serial device from labview 4.0.1 using a usb to db-9 serial converter cable. The device wants a baud rate of 115,200.
NI-VISA 2.0.1 VISA interactive control for LV4 DOES communicate with device at 115,200. However, The device is not recognized even when I do a write from the preprogrammed ni serial vi's. I have double and triple checked the settings. I have also completed the loopback test, but that would also fail stating "device not found".
Can I communicate with this serial device with old versions of labview?
notes:
It does work when programming a vi with the student edition LV7.1.
thanks,
Stuart
