04-23-2009 12:20 PM - edited 04-23-2009 12:23 PM
I am doing some experiment with NAT9914xx. I understood from various sources that this ASIC is connected to the GPIB bus through some transceiver ICs, i.e. TI's SN75ALS160 and SN75ALS162. Whilst I'm waiting for the part, I wish I can carry out some testings.
So here is the question: If the only devices exist on a GPIB bus is my testing board and a GPIB capable equipment, can I have the NAT9914 on my testing board connected directly to GPIB bus without using the transceivers?
Thanks & best regards,
WH Tan
Solved! Go to Solution.
04-24-2009 08:16 AM
These transceivers are absolutely necessary when communicating with GPIB instruments. That is why they are in the hardware section of the 9914 manual. The transceivers will output the correct voltages/line transitions. Without them, there will be errors in communication.
I hope this helps,
Steven T.
04-25-2009 07:35 AM
Steven,
Thank you very much. I appreciate your reply.
Besr regards,
