Showing results forĀ
Search instead forĀ
Did you mean:Ā
.NET Framework 2.0 Languages Support for VB 2005 Express
Can anyone give me advise on the following issue?
I am using VB2005 Express and try to install the NI488.2 ver 2.4 for my GPIB-USB-HS. However, I cannot found the .NET Framework 2.0 Language Support in the installation option, just only the NET Framework 1.1 Language Support. Can I use this 1.1 Language Support? I doubt with this because VB2005 Express is using .NET Framework 2.0.
Best Regars,
YC
Message 1 of 9
(5,341 Views)
Hey YC,
Do you happen to have the device driver CD? I think you should be able to find the 2.0 support that you need if you install the drivers from the device driver CD, instead of the drivers from online.
Nick D.
Message 2 of 9
(5,315 Views)
I'm time to time using Visual Studio 2005 Express Edition(C++). There's no problems with using NI488.2 .NET classes in my applications. Probably they were written for .NET 1.1, but also working under .NET 2.0 without problems. Just using NationalInstruments.NI4882.dll from \Program Files\National Instruments\MeasurementStudioVS2003\DotNET\Assemblies\Current.
For example:
using namespace System;
using namespace System::Threading;
using namespace NationalInstruments::NI4882;
#define Sleep(t) Thread::Sleep(t)
void GPIBOpen(Device^ dev,int addr);
void GPIBWrite(Device^ dev,String^ s);
String^ GPIBRead(Device^ dev);
int main()
//Open GPIB
Device^ id;
GPIBOpen(id,1);
//Write to GPIB
GPIBWrite(id,"test");
//Read from GPIB
Console::WriteLine("Read from GPIB: \""+GPIBRead(id)+"\"");
return 0;
//GPIB is closed automatically, when program is exiting
try
dev=gcnew Device(0,addr);
dev->Clear();
catch(Exception ^e)
Console::WriteLine(e->Message);
Console::ReadKey();
Environment::Exit(-1);
try
dev->Write(s);
catch(Exception ^e)
Console::ReadKey();
Sleep(30);
try
return dev->ReadString();
catch(Exception ^e)
Console::ReadKey();
return String::Empty;
It's compiling successfully even with /clr:safe key.
I not tested it thoroughly, so use at Your own risk.
Best Regards,
NoAngel
Message 3 of 9
(5,305 Views)
Hi NoAngel,
Thankyou for your advise. I will test the compatibility of it.
One thing I have noted is that the help function of the Measurement Studio cannot be integrated into the VS2005's IDE as like that in VS2003 edition.
Best Regards
YC
PS. I install the device driver from the CD and cannot found the 2.0 Languages Support.
Message 4 of 9
(5,284 Views)
Yes, I had the same problem. Help 2.0 is not integrating with Visual Studio 2005 Express Edition. But we can use third-party tool to view help, Help 2.0 custom Viewer:
http://frogleg.mvps.org/helptechnologies/mshelp2/h2viewer.zip
Try to download it, use "File->Open name space...", select NI... namespace.
Best Regards,
NoAngel
Message 5 of 9
(5,282 Views)
Hi NoAngel,
Thankyou very much for your informantion. I have got it!
Best Regards,
YC
Message 6 of 9
(5,277 Views)
I'm very interested in this post. Can anyobody attach some Visual Basic 2005 express example??
Thanks.
Message 7 of 9
(5,084 Views)
Hey Baguel,
Have you tried implementing the same strategy as above, but using the folder:
\Program Files\National Instruments\MeasurementStudioVS2005\DotNET\Assemblies\Current.
Nick D.
Message 8 of 9
(5,030 Views)
Thaks a lot, NIck. I'll try that.
Message 9 of 9
(5,017 Views)
