NI-488.2 GPIB software not correctly installed
I am having a lot of trouble just to get this software to install properly - the troubleshooter complains that it has not installed, and asks me to reboot and reinstall.
I have now tried this several times, each time going through the installer successfully, but failing on the verification.
It has worked on other laptops, with the very same GPIB PCMCIA card. Device manager shows no conflicts and is happy with the drivers given. But the programs written by my colleague cannot access the instrumentation.
Help!
Sara
(3,951 Views)
Hello Sara,
What version of the NI-488.2 software are you trying to install? And what operating system are you running this on?
Can you post a screen shot of the troubleshooting wizard, with the message that it displays to this post?
If you can post this back, I'll take a look and see what could be causing this issue.
Regards
Hannah
NIUK & Ireland
(3,908 Views)
still no solution for this? I'm having the same problem.
I have installed NI-488.2 1.7 and NI-VISA 5.0.2
MAX can't find my instrument via GPIB, and the troubleshoot say this:
http://grab.by/grabs/556f25ffa4624e37945994ba404284fa.png
(3,553 Views)
Hello PabloT,
This post that you have replied to is old.  For better visibility with the NI Community, create a new Forum Post explaining which hardware you are using, and your system specifications.
Active members of the forum will reply with their suggestions.
George T.
Senior Applications Engineer
National Instruments UK and Ireland
(3,525 Views)
ok Thank you
(3,521 Views)
