NI -488.2 GPIB
I am Sze Yuen Cheng from Osram Sylvania Inc. I have a few questions about your NI-488.2 GPIB. I need to use the GPIB to interface a few Xitron power analyzer instruments with the computer by using Visual Basic 6, and this is the first time that I am using both Visual Basic and GPIB. I found 2 files from the NI-488.2 software CD: one is called Vbibi-32.bas and the other is Niglobal.bas. What are these files? Are they just the initialization and variable definitions for the GPIB hardware? Do I have to include these files with the Visual Basic program in order to communicate between the computer and the instruments through the GPIB? How can I include these files in the Visual Basic program? What are the most important things that I have to know
or acquire from the Vbibi-32.bas and the Niglobal.bas files in order to finish my task? I am going to attach these 2 files for your references.
If you need more information, please contact me at sze.cheng@Sylvania.com or 847-726-6258.
Thank you,
Sincerely,
Sze Yuen Cheng
(3,615 Views)
You have found the right two files! These two files make up what we call the "language interface files" for VB. You can find out more here: http://sine.ni.com/apps/we/niepd_web_display.display_epd4?p_guid=B45EACE3D90756A4E034080020E74861&p_node=DZ52353&p_source=external
In summary:
NIGLOBAL.BAS: global module containing predefined constant declarations
VBIB-32.BAS: source file containing NI-488.2 routine and NI-488 function prototypes
I always find that the best way to learn is by example. There should be some basic examples that installed with your NI-488.2 driver. If you installed it to the default path, it will be located in C:\Program Files\National Instruments\NI-488.2\Languages\Visual Basic
Take a look at those examples. They should hel
p you get on your way.
Best Regards,
Aaron K.
Application Engineer
(3,615 Views)
