Just to make it clear, when you send the reset command, the instrument does in fact reset correct? After the 5 seconds, does the communication continue to work as expected? I am somewhat surprised that you would be getting this error, but when the instrument is resetting, you most likely would not be able to communicate with the device.
You may want to examine a SPY log of the communication to ensure that you are sending exactly what you think you are. One thing that comes to mind is a "double '\n'" at the end of your string. If the term chars are automatically appended, and you send two of them during the reset, the instrument may stop responding before the second char was sent and cause the error. NI-Spy should be able to help you examine cases li
ke that more closely. This can be executed from the tools menu of MAX.
Hope this helps out!
Best Regards,
Aaron K.
Application Engineer
