NI-488.2 .NET API - slave / non-controller mode
We want to use your NI PCI-GPIB as slave – I found following entry here
https://forums.ni.com/t5/Instrument-Control-GPIB-Serial/GPIB-Slave-with-NI488-2/td-p/838953
and the noncic.zip ‏application there works as expected
But I want to use C# programming language and the .NET library (no wrapper)
I also found following function mapping description
http://zone.ni.com/reference/en-XX/help/370628F-01/mstudiowebhelp/html/gpibapimapping/
The status can be read by the device class method GetCurrentStatus()
http://zone.ni.com/reference/en-XX/help/370628F-01/mstudiowebhelp/html/31047307/
I also found a way to set the current status byte (ibrsv) – also a device class method SetConfigurationOption()
http://zone.ni.com/reference/en-XX/help/370628F-01/mstudiowebhelp/html/a87535c1/
Was a little bit tricky, because this method is not visible
       [EditorBrowsable(EditorBrowsableState.Never)]
        public void SetConfigurationOption(int configurationOption, int configurationOptionValue);
https://linux-gpib.sourceforge.io/doc_html/reference-function-ibconfig.html
IbcRsv
0x21
Sets the current status byte this board will use to respond to serial polls. Same as ibrsv().
But how can I disable the system control capability
ibrsc (_board, 0);
Are the any .NET slave examples available?
Many thanks for your time.
(3,613 Views)
Hello will you able to make it work with C#?
Also, can you help me how you run noncic.zip?
(2,822 Views)
Sorry, but the project was never realized.
I wish you all the best.
(2,808 Views)
Its oks, I will try to make it work, but C++ GPIB driver library could do as well.
Aside from noncic.zip, created at Visual Studio C++ 6.0, were you able to manage to create or update your custom NI PCI-GPIB slave instrument?
Cheers,
Raymond
(2,800 Views)
