convert usb raw driver to usbtcm driver for Owon oscilloscope xds2102a
I've just connected my new oscilloscope Owon xds2102a to my labview system using owon's driver.
But there is a problem: NI VISA shows it's the USB RAW instrument . SCPI commands such as idn, read, etc. go well , besides, read command gives at the end \n.
But the main problem that I definitely need the oscilloscope to be seen as USBTMC.
I wonder if there any chance to convert USB RAW to USBTMC?
Message 1 of 9
(3,684 Views)
There is no chance, because for converting to USBTMC you have  to modify the scopes firmware to use USBTMC protocol instead of the currently used propriatary protocol.
Message 2 of 9
(3,612 Views)
Thank You.
One more question:
How can I fix the "...\n" that appears at every oscilloscope's reply to any my command?
Message 3 of 9
(3,600 Views)
You might be able to change that in the scopes setup.
But \n ( end of line) is used as termination character here and means that there is no other data is following in this response. So what's the problem with that ?
Message 4 of 9
(3,589 Views)
Thank You,
I shall try to find this setting in my oscilloscope, but right now I dont't see this option.
The problem with "\n" is following:
my measurements data go to a table then goes to a graph.
When I write ":MEAS..." to an agilent device the read command gives "1.123"
When I write ":MEAS..." to this owon oscilloscope device the read gives "1.123\n"
So my data table becomes corrupted .
Message 5 of 9
(3,571 Views)
Which software do you use to process the data ? Are there no options for string manipulation before filling the table ? I.e searching for the \n at the end of the reading an removing it , if it exists.
Message 6 of 9
(3,548 Views)
Thank You,
I use Origin. Yes,I can import  data with option of recognition of "\n", but I hoped to get rid off "\n" on NI-VISA level.
PS: I still can't find the option converting USBRAW to USBTCM in my oscilloscope.
Message 7 of 9
(3,542 Views)
Hi, I have this oscilloscope too. Where did you find commands list to control the device from PC via serial port?
Message 8 of 9
(3,350 Views)
http://files.owon.com.cn/software/Application/XDS3000_Dual-
Channel_Series_Oscilloscopes_SCPI_Protocol.pdf
Message 9 of 9
(3,333 Views)
