NI-488.2 WinXP
Will the NT 4 drivers work with WinXp prof.?
(3,339 Views)
This depends on what hardware and drivers you are using. For instance, NI-488.2 version 1.70 works on both Windows XP and Windows NT 4.0. You can check if your hardware is supported at the Current GPIB Driver Versions page.
http://www.ni.com/support/gpib/versions.htm
Geneva L.
(3,339 Views)
