NI 488.2 driver not working on Windows 7 if called from apache web server
We have an application on Win2K where an apache web server controls instruments via the NI488.2 library (cgi scipt with a c-wrapper around the dll), which is working fine.
After porting the whole application to Win7 and calling  the same script from the command line, it is still working fine.
But if the same script is called by the apache server, the connect to the instrument fails, status is 0x8000 .
Here is the NI Spy log:
> 1.  ibdev(0, 5, 0 (0x0), T1s (11), 1, 0x0000)
> Prozess-ID: 0x0000056C         Thread-ID: 0x00001DD0
> Startzeitpunkt: 15:02:51.506       Aufrufdauer 00:00:00.000
> ibsta: 0x8000       iberr: 0             ibcntl: -535560155(0xe0140025)
> 2.  ibclr(?board?)
> ibsta: 0x8000       iberr: 23             ibcntl: 0(0x0)
For reference, this is the the NI spy log if called via the command line:
Prozess-ID: 0x00001AB4         Thread-ID: 0x00001DF8
Startzeitpunkt: 15:03:42.634       Aufrufdauer 00:00:00.027
ibsta: 0x100       iberr: 0             ibcntl: 0(0x0)
7.  ibclr(UD0)
Startzeitpunkt: 15:03:42.661       Aufrufdauer 00:00:00.072
ibsta: 0x100       iberr: 0             ibcntl: 4(0x4)
We are using the GPIB-USB-HS and NI-488.2.2.72
What is giong wrong here?
Message 1 of 1
(3,388 Views)
