PCIS-8580-13S
Can I install a PIC-GPIB card into a PCIS-8580-13S(EA) and control equipments via that GPIB?  Thanks.
(3,295 Views)
liutm,
If that device is simply a PCI bus expander, then any PCI card should work in any of those slots the same way they would work as plugged direclty into your PC. This means that it should work.
We offersimilar type products to expand your PCI bus with a PXI system. You can certainly use a PXI-GPIB card in these systems.
Peter Flores
(3,269 Views)
