NI-488.2 v. 1.70 aborts install on Windows 2000 with Error 1311 - can't find m4.CAB
NI-488.2 v. 1.70 aborts installation on a Windows 2000 PC with the error message "Error 1311 - can't find m4.CAB." The installation was attempted from a NI CD part number 500739E-00 (July 2000).
There was no GPIB card present in the PC at the time of the installation. I am running Windows 2000 Professional SP2, build 2195, on a Dell Precision 340 workstation.
(4,179 Views)
Hello-
It could be a bad CD. Does m4.cab exist. What is its size and modified date? Is it possible to attach this file to the next response?
Randy Solomonson
Application Engineer
(4,179 Views)
m4.cab exists. It is located in the NI-488.2 folder of the installation CD. Its size is reported as "Size: 44.6 KB (45,751 bytes). Size on disk: 46.0 KB (47,104 bytes). [Created and modified] Thurs September 07, 200, 7:54:19 AM."
The m4.cab file appears as a WinZip file, with a WinZip icon.
Again, the CD part number is 500739E-00 (July 2000). The application is NI-488.2 for Windows, version 1.70.
(4,179 Views)
Here is the m4.cab as an attachment.
(4,179 Views)
Hello-
This looks valid. Although it is rare, sometimes the MSI installer has trouble copying the files from CD ROM drives. Try copying the contents from the CD to a local harddrive and installing from there. This will usually fix this problem.
Randy Solomonson
(4,179 Views)
Randy,
I got success by copying the NI-488.2 folder from the CD to the Hard Drive and installing from the Hard Drive.
Thanks for the info.
One other question: do you know if NI plans to add C# support to its NI-488.2 language interface?
(4,179 Views)
There are currently two options for using GPIB in C#:
1) Use the dll provided by the visa driver using #import in C#
2) Use our current VISA ActiveX control in C# (ships with MStudio 6.0)
MSDN can help with option number one.
Randy Solomonson
(4,179 Views)
