09-22-2008 05:48 PM
I am getting this error when trying to communicate to a designed Telnet device. using TCP/IP Open and close commands. The system does not even have a GPIB controller in it. It may be internal to the product we are testing, since the unit passes the 2nd time through. But all I am doing is opening a TCP/IP connection 192.168.168.168 port 50101 sending command to GET MEAS and reading back a string, then close the TCP/IP. Pretty simple. It doesn't open the port and gives the GPIB 01 error. Could it be the VISA controller causing this?
It errors out when it gets to TCP/IP open.vi
ljark
09-22-2008 06:20 PM
Read the error message more carefully. There are two possible reasons for error 1. Since you are not using GPIB, you should consider the other possible reason:
LabVIEW: An input parameter is invalid. For example if the input is a path, the path might contain a character not allowed by the OS such as ? or @.
