NI-8451 with Windows Embedded
Is the NI-8451 not compatible with Windows Embedded? I have LabVIEW up and running but I can't seem to get the 8451 drivers to install. When I run the driver setup I do not receive any error messages to give me any indication that something went wrong. Thanks for the help.
(4,265 Views)
Accepted by jmountney
Hi jmountney,
Yes, NI-8451 is compatible with Windows Embedded.   Depending on your version of Windows, you might have to add additional packages.  The recommended template to include is the "Application Compatibility", which should include everything you need.
Nick
(4,249 Views)
