NI IO Trace
I have an old Mac running an old version of LabVIEW and I need to see if signals are successfully going out to a GPIB device.  Can I use NI IO Trace running on a new laptop with a GPIB-USB adapter between its UBS port and the stack of GPIB connectors and record any signals?
(3,117 Views)
I do not believe the NI IO Trace function will tell you the information that you are looking for.
I would recommend using a Loopback test to see if your device is working correctly.
This link should have instructions to help you with performing that test.
How to Do a Serial Loopback Test
Casey G.
(3,081 Views)
