NI MAX AND NI VISA NO SUPPORTING MY ASF USB(ATMEL with vid=03eb & pid=2423)
i am using NI-VISA Driver Wizard  to make driver of my  "ASF USB" (ATMEL  WITH
VID=03EB & PID=2423)  as shown in NI-VISA Driver Wizard.png  and you can see
(numberofopenpipes: 0) then i make a driver and  it successfully connect my
device then i open NI max  to test my usb device   ni max detect my device as
can be seen in  image (ni max1. png) and when i open visa test pannel it show
bulk in pipe= no pipe present ( as highlighted in (ni max 2.png) and if i set
these value  and apply changes it shows an error  which can be seen on (ni
max3.png)
NOTE: unzip attached image.zip folder  to see all referred images.
what can i do to get my device to properly work with ni visa?
i think NI visa is showing (numberofopenpipes:0)  that's why i am having this
issue.
how  can it be resolved ?
please provide a possible solution as i am stuck with it for nearly 2 day.
i have tried my USB device with other driver  and software and i was working.
(2,898 Views)
Do you know if a driver already exists for this device? If not, you've gone the correct path by trying to use the VISA Driver Wizard.
Are you able to send the device a *IDN? command?
Mike B.
Technical Support Engineer
(2,862 Views)
no i am unable to send an *IDN? command because every time i sent it shows an errorview attributes.PNG
(2,856 Views)
