01-31-2018 03:41 AM
i am using NI-VISA Driver Wizard to make driver of my "ASF USB" (ATMEL WITH
VID=03EB & PID=2423) as shown in NI-VISA Driver Wizard.png and you can see
(numberofopenpipes: 0) then i make a driver and it successfully connect my
device then i open NI max to test my usb device ni max detect my device as
can be seen in image (ni max1. png) and when i open visa test pannel it show
bulk in pipe= no pipe present ( as highlighted in (ni max 2.png) and if i set
these value and apply changes it shows an error which can be seen on (ni
max3.png)
NOTE: unzip attached image.zip folder to see all referred images.
what can i do to get my device to properly work with ni visa?
i think NI visa is showing (numberofopenpipes:0) that's why i am having this
issue.
how can it be resolved ?
please provide a possible solution as i am stuck with it for nearly 2 day.
i have tried my USB device with other driver and software and i was working.
02-01-2018 05:15 PM - edited 02-01-2018 05:16 PM
Do you know if a driver already exists for this device? If not, you've gone the correct path by trying to use the VISA Driver Wizard.
Are you able to send the device a *IDN? command?
02-01-2018 09:50 PM - edited 02-01-2018 10:16 PM
no i am unable to send an *IDN? command because every time i sent it shows an error
