NI MAX returning wrong data on non-SCPI instruments
I am trying to use an NI USB to GPIB converter to read data from an HP8563E and an EMCO 1060 turntable controller. In both cases the data that comes back on a read command using the VISA interface in MAX is not coming in correctly. The data is close but seems to be scrambled up slightly. Both of these are old non-SCPI boxes. I am not sure if the NI device is capable of reading these correctly, or if there is some set-up that I do not understand. Any help would be appreciated.  Thanks!
(4,604 Views)
Hi Stewart,
It seems like a driver issue, the instrument driver can be found here: http://sine.ni.com/apps/utf8/niid_web_display.download_page?p_id_guid=047150BB30A857EAE0440003BA7CCD...
What version of VISA do you have? I think it is worth while updating to the latest version. The latest is 15.5 and the downloading link is: https://www.ni.com/en/support/downloads/drivers/download.ni-visa.html
Ren H.
Applications Engineering
(4,565 Views)
Thanks for the help Ren. I am using the NI Measurement and Automation Explorer VISA Test Panel in version 15.3.0f0
All I am trying to do is read data back from the instrument one command at a time for troubleshooting purposes. The driver you pointed to may help with the 8563E SA, ( Although it is not clear which of the 4 links I would need since I do not have a copy for LabView.)
However, I could not find a driver on your website for the EMCO Model 1060 Turntable Controller which has the exact same problem as the 8563E. Do you have a driver for that box?
How would I be able to tell which driver to load out of the 4 choices?
Thanks for the help.
Chris
(4,558 Views)
Hi Chris,
Since you are not using LabVIEW, the instrument driver is not necessary as they are essentially NI-VISA calls. I think it might be a setting issue since the returned data is close but scrambled slightly. Can you make sure the VISA settings are correct, like the baud rate.
If you send a very simple command, like *IDN?\n, does that work properly? A loopback test is also worth a try.
Ren H.
(4,546 Views)
