Timeout Expired error for RS485 loopback test
Hi everyone,
When I was doing a loopback test for a B&B USB to RS-485 mini-converter (4 wires), I am getting the meassage like
"Read Operation
Error
VISA:  (Hex 0xBFFF0015) Timeout expired before operation completed. "
The loopback test was performed with NI MAX,  and the steps are exactly follow the NI tutorial in the following link
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000YFtECAW&l=en-US
I varied the byte to read numbers and timeout vaules, but I got the same error.
I am pretty new to the instrument control.  Does anyone have any idea about this?  Do I need to get a new RS485 connector?  Thanks.
By the way, I did a similar loopback test for a RS232 connector and it work.
(4,101 Views)
It looks like your connector is failing the loopback test. Make sure you have the connections correct (they're different for RS 232 and RS485), and check with a different RS485 connector if you can. I believe you will need a new RS485 connector.
(4,066 Views)
