NI MAX
I am having problems getting MAX to recognize instruments.
It only sees two power supplies
However, The VISA interactive control Sees all of the instruments.
I have downloaded the latest version of DAQmx, Visa and 488.2, but it still has the problem.
I don't know if this has anything to do with it, but some of the articles I read said to use the 488.2 utility in the tools menu. This is not showing up in the menu.
Another article suggested checking the properties of the USB-GPIB-HS properties. That option also is not available.
What am I missing? I do not have this problem at any of the other stations
(2,511 Views)
Try resetting MAX configuration.
(2,016 Views)
