NI USB 8451
Hi...Could u pls let me know how to do a self test (loop back test ) using LabView on the NI USB 8451 DAQ...What pin configurations/connections do I need to change to do a self test?
(PS..There isnt an option in MAX unlike DAQmx)
(3,953 Views)
I2C loopback needs an external handshake, spi can be done, but why and what are you needing a loopback
greetings from the Netherlands
(3,944 Views)
I use SPI for writing into certain registers,and I just wanted to test it using self test feature (if any) .. could u explain how to do for SPI ?
(3,943 Views)
expect a delay of one clockcycle and write and read a number of bits.
connect daat out to data in (clk is already avalable and see what happens.
(3,939 Views)
