NI VISA LINUX RHEL 7.2 installation conflicts with CVI Linux Run Time Module
I had installed the LABWINDOWS/CVI 2013 RUN TIME MODULE for LINUX on a RHEL 7.2 Linux system and then attempted to install NI-VISA 17.0 for Linux on the same machine and got many conflicts (see attached image).
Everything seem to make sense as far as the prompts went but perhaps I did something incorrectly during the install, two NI Products both for Linux should NOT have this many conflicts.
(3,003 Views)
Hi jschafer10272,
Would you be able to post the console output before and after the file conflicts methods? Including the setup for the installation and the end result?
I wasn't able to find any information on incompatibilities between these 2 files so I am not sure what would be causing these conflicts. Would you also be able to try installing NI-VISA before installing the LabWindows/CVI Run-time Engine?
Also, are both of these files being installed from the downloads on our website? There may have been something wrong with the NI-VISA download. We can verify this by verifying the checksum using the article I have posted below.
Verify Validity of My Downloaded Installation Files: http://digital.ni.com/public.nsf/allkb/48ADD3EC8940ACE886257D7B0061F542
ShaneK
Applications Engineering
(2,955 Views)
I believe the CVI Run Time Module for Linux was installed from the DVD supplied by NI.
The NI VISA driver was downloaded from the NI website and installed from a USB drive.
I will look at this article and perhaps attempt to reinstall it.
(2,924 Views)
