NI-VISA Server and embedded PC X86
Dear All,
I'm working on a project which involved integration of differents sensors on an U.A.V.
The sensors will be connected to a mobile X86 embedded PC, and the data will be transmitted to a standard PC on the ground using radio transmission.
I'd like to create a NI-VISA server from the PC base station (client) to the embedded PC (server) to acquire the data of the sensors.
I'll use 2 RS232 radio modems connected on both PCs for the transmission, the radio transmission will be transparent.
Both PCs will run on windows 7 64 bits.
Do you think this application would be easy to configure?
Do you have any recommandations on it, or other ideas for my application?
Concerning the embedded PC, we are interested to use a Fit-PC from CompuLab company (mobile X86 platform).
Thank You for your reply
Laurent
Message 1 of 1
(4,373 Views)
