unable to detect agilent E5061B in NI MAX with VISA tcp/ip
I am using LV2011 and VISA 5.4
I am unable to detect my Agilent E5061B with LAN connection.
* When using cmd.exe I can "ping" the instrument with the already set IP-adress.
* The instrument will not be present when I am creating a new VISA TCP-IP device
Has someone a description or a check-list I can follow?
Best regards
Oddgeir
(5,019 Views)
Have you installed Agilent I/O Libraries on your computer?
It can help with troubleshooting.
Also, reading chapter 12 of the downloadable Help File - User Manual would be helpful as well.
(5,004 Views)
Problem solved.
The solution is in the details. I have done several actions, and I am not shore whats requisite.
In the Agilent instrument - Network setup:
 - SICL-LAN server ON
 - Web server ON
In NI MAX:
 - VISA setup, check to Run the VISA server on start-up
Oddgeir
(4,970 Views)
