NI_VISA install errors on Windows 2008 R2
I am having the exact same issue with the visa 5.4.1.  I have tried the full visa driver as well as the visa run time engine with similar results.
Matt Davied
Worrying is like a rocking chair, it gives you something to do, but never gets you anywhere.
Message 11 of 12
(1,206 Views)
Hi Matt,
Apparently this error has to do with a component of the VISA installer not jelling with the remote desktop services connection for Windows Server 2008.  The following link goes over how to disable that, which as worked for previous customers.
http://technet.microsoft.com/en-us/library/cc731588.aspx
If you still can't get anything to install, it would be great if you could make an install log file and either post it here or PM me with it.
-Jim B
Applications Engineer, National Instruments
CLD, CTD
Message 12 of 12
(1,185 Views)
