NI-Visa Enabling - Save Conflict Manager Settings
Hello!
I'm experiencing some problems regarding the Enabling of NI-VISA 5.2 within NI MAX (See screenshot in attachment).
I'm usng Labview 2009 and Win7. I guess you'll need much more information on my System.
From the Message prompted it seems It could be related to some sort of permission while saving the settings, but this problem is not risen within other areas of NIMAX.
At the beginning, Agilent Visa was installed along with NI-VISA 5.2 and the former one was Enabled in Conflict Manager.
After that I installed NI 488 2 3.1.1 Drivers and when later I needed to enable NI-VISA I ran through this problem.
(I don't know whether before the NI488 installation I could switch to NI-VISA, I didn't try at that time)
I uninstalled Agilent Visa, I Installed NI-VISA 5.3, Repaired, Uninstalled 5.3, reinstalled 5.2 but I'm still facing the same prompt.
Thanks for Any Help!
(6,302 Views)
Accepted by topic author Knyquist
Try to read the following KBs, they should be helpful for answering the problem.
Using NI-VISA 5.2 or greater with the Agilent E5810A LAN/GPIB Gateway
http://digital.ni.com/public.nsf/allkb/C6ADD4D65354570086257AA1002F5F67?OpenDocument
Configuring NI-VISA as the Primary VISA
http://digital.ni.com/public.nsf/allkb/B283196340462DFD86257633006DC799?OpenDocument
Enrico D.
(6,258 Views)
Thanks!
I will not be able to test shortly your solutions
but after having carefully read your links it seems clear to me where the problem is and how it can be solved!
Thanks again for following up!
Grazie!
(6,254 Views)
