NI WSN 9197
Good evening, I have a sensor network device wireless NI WSN-9791 and I'm struggling to it to be detected by the PC in the MAX program.
Tou following in the footsteps of a document available on your site to configure the device and at the very beginning when asked to expand Remote Systems does not detect the WSN-9791 and when I try to manually detect put the default host name of the device and prompt an error that says "Unable to initialize connection to remote target (s)" as demostro in the Annex.
I wonder how surpass this error and how I can for the PC to detect the device automatically.
Thanks for listening
Nuno Monteiro
(4,473 Views)
Hello M. NUNO MONTEIRO,
Could you please precise me the MAX version used ?
Could you try to establish a local connection with an ethernet cable as the guideline belows to verify if a gateway can be properly done ?
https://www.ni.com/docs/en-US/bundle/373730a/resource/373730a.pdf
Lets me know the result
Cordially
Arnaud
GENEBRIER
Ingénieur d'Application | (NI France)
(4,421 Views)
I use the latest version
When i establish a local connection with an ethernet cable nothing appears on the max.
Can you tell me what programs do I need to install to the program detects devices?
I think this is to be my problem
Nuno Monteiro
(4,412 Views)
Good morning,
You can refer to this page and according to the OS and LabVIEW Version used download the right driver version
https://www.ni.com/en-us/support/model.wsn-9791.html
Cordially
(4,396 Views)
Hello! I have modules WSN-9791 and WSN-3212. It is necessary to connect over the Ethernet WSN-9791 to the PC. But there is no IP address and subnet mask. What to do?
(3,337 Views)
