Keithley 2410 - VI_ERROR_TMO: Timeout expired before operation completed.
I'm trying to control a Keithley 2410 via python on an x86_64 linux machine (CentOS 7). I'm using python 2.7.5, NI-VISA 16 and PyVISA 1.8. The Keithley is connected to the computer via a a RS232-to-USB cable and it's configured for RS232 communication (with the parameters: baud 57600, bits 8, parity none, terminator <LF>, flow-ctrl none). When I try to query the Keithley I get a timeout error, as shown below:
>>> import visa
>>> rm = visa.ResourceManager()
>>> print(rm.list_resources())
(u'ASRL1::INSTR', u'ASRL2::INSTR')
>>> keithley = rm.open_resource("ASRL2::INSTR")
>>> print(keithley.query('*IDN?'))
Traceback (most recent call last):
File "<stdin>", line 1, in <module>
File "/usr/lib/python2.7/site-packages/pyvisa/resources/messagebased.py", line 407, in query
return self.read()
File "/usr/lib/python2.7/site-packages/pyvisa/resources/messagebased.py", line 332, in read
message = self.read_raw().decode(enco)
File "/usr/lib/python2.7/site-packages/pyvisa/resources/messagebased.py", line 306, in read_raw
chunk, status = self.visalib.read(self.session, size)
File "/usr/lib/python2.7/site-packages/pyvisa/ctwrapper/functions.py", line 1582, in read
ret = library.viRead(session, buffer, count, byref(return_count))
File "/usr/lib/python2.7/site-packages/pyvisa/ctwrapper/highlevel.py", line 188, in _return_handler
raise errors.VisaIOError(ret_value)
pyvisa.errors.VisaIOError: VI_ERROR_TMO (-1073807339): Timeout expired before operation completed.
Any suggestions as to what the problem(s) might be would be much appreciated!
(8,477 Views)
Not used Python but have used Visa with serial busses. You need to make sure there is a linefeed appended to the end of the command.
(8,433 Views)
Thanks for the suggestion. When you say a linefeed I guess that you mean "\n"? It is my understanding that PyVISA adds this to the query automatically but, even if it doesn't, I tried adding the "\n" explicitly and unfortunately it didn't seem to work.
(8,424 Views)
Well the only other things are:
Cable needs (assuming 9 pin to 9 pin) needs to be staright through. Pin 1 to Pin1, Pin 2 to Pin 2 etc
Instrument is configured for the same baud rate etc as Visa
(8,419 Views)
Thanks for the help. It seems that I needed to explicitly set the baud rate in my python script.
smu = rm.open_resource("ASRL2::INSTR")
smu.baud_rate = 57600
Thanks again.
(8,331 Views)
