SMAC Actuator: PuTTY works but LabVIEW VISA Write fails
Hi All,
I am trying to control the SMAC LCA8-010 actuator with LCC-10 controller. I wrote my functions in LCC-10 as macro functions with SMAC provided "Control Centre" software, and used LabVIEW VISA Write to call them.
I tried PuTTY first and it runs smoothly. But when I tried to run them in LabVIEW ("Control.vi" attached), for most of the time, the motor doesn't move, and the Property Node "Byte at the Serial Port" returned a 0, which means the "Write" function does not write anything to the controller.
What is strange is that it succeeded for some time (~10% of test runs). So the input format is correct. I am thinking about if the difference in mechanism of PuTTY user input and LabVIEW VISA Write function could make a difference.
Can anyone help me with that? Thanks a lot!
(3,727 Views)
Putty and LabVIEW differ in two ways. First but probably not really important is the speed. Putty transfers characters more slowly than LabVIEW after each other. You can add a small delay by defining two stop bits or to transfer each character in a for loop with visa write. But more importantly Putty uses CRLF instead of just LF so use /r/n in your string write.
greetings from the Netherlands
(3,677 Views)
Hi Albert,
Thanks for your answer!
Can you elaborate a little bit about "defining two stop bits"?
Yes I indeed suspect about the speed, and I've tried to change the input mode to character-by-character using https://forums.ni.com/t5/Example-Code/Serial-Write-One-Character-at-a-Time/ta-p/3996032. I set the time gap from 4ms to 50ms.
However, same problem happened: it works but only sometimes.
May I ask for more options to try? Please let me know!
(3,675 Views)
Hi "1 at a a time.vi" is Ok to use but I would wait 0 time between two writes.
And instead of extracting each character from the string I would use convert string to byte array and in a for loop send each character with build array and byte array to string. Without having a wait.
2 stopbits can be found in "VISA Configure Serial Port (Instr).vi" it determines that each serial character is followed by two bit times of inactivity on the line. Normal behaviour is 1 stop bit and on USB even that is not for sure.
I have the feeling that the cr/lf option is the better way to go and also try to read until you get an end character instead of using a wait and bytes available.
Using/ enabling end characters means that you ask a too big number of bytes say 255 and the function automatically stops reading from the buffer at the first end character.
(3,666 Views)
