11-01-2017 07:00 PM
Friends,
Can my 6353 X-series DAQ be used for data readout from a stanford research 844 lock in amplifier. The lock in offers RS 232 and GBIP connectivities?
11-01-2017 07:22 PM - edited 11-01-2017 07:27 PM
Are wanting to remotely control the SR844 or just read back signal? Your question is a bit vague or confused.
The SR844 has analogue output which you can capture with you daq by wiring to its AI. You can thus digitise your analogue signal and save the data to a file.
But you daq cannot make use of rs232 or GPIB interfaces to communicate with and control settings on the instrument. For that you need a serial cable from instrument connected to serial port on the pc, a serial/usb adaptor if you don't have serial port on pc, or a GPIB cable and card or a gpib-usb connected between instrument and pc.
Hope that helps.
11-01-2017 07:54 PM
Yes, I just need it for data read out basically for imaging purpose.
