National instruments and stanford research lock in amplifier
Friends,
Can my 6353 X-series DAQ be used for data readout from a stanford research 844 lock in amplifier. The lock in offers   RS 232 and GBIP connectivities?
(2,952 Views)
Are wanting to remotely control the SR844 or just read back signal? Your question is a bit vague or confused.
The SR844 has analogue output which you can capture with you daq by wiring to its AI.  You can thus digitise your analogue signal and save the data to a file.
But you daq cannot make use of rs232 or GPIB interfaces to communicate with and control settings on the instrument.  For that you need a serial cable from instrument connected to serial port on the pc, a serial/usb adaptor if you don't have serial port on pc, or a GPIB cable and card or a gpib-usb connected between instrument and pc.
Hope that helps.
(2,940 Views)
Yes, I just need it for data read out  basically for imaging purpose.
(2,932 Views)
