Need a NI 488.2 driver for Susle Linux 11.1 (X86_32) to access my GPIB ENET/100
I have Suse 11.1 installed on my PC (X86_32). But I cnnot compile/install NI-488.2-beta-2.5.1b1. If I follow the instruction within the README.txt, the script finally stop with an error message, that the installed kernel is compiled with a different gcc version. I am using the kernel comming with Suse 11.1 and I don't want to recompile the kernel
It is a share library for NI488.2, not a kernel module. Am i right ?
(3,621 Views)
Right now only Suse Linux distributions up to version 10.3 are supported, a list of supported distributions can be found here.
(3,604 Views)
Thanks for the hints. I also figured out some more steps. There is already a newer version of NIKAL available (1.9.0f0) for SUse 11.0. But this will not compile with the kernel devlivered with SUSE11.0 or 11.1. You need to recompiled the kernel with NUMA support disabled. After that the kernel variable "max_mapnr" is available and the NIKAL kernel module will compile.  Earlier versions of NIKAL have problems to get the GCC version.
I installed the following driver and GPIB modules/libraries
nikal-1.9.0f0
  labview80-rte-8.0.1-1
  nikali-1.7.0-f0 not installed, because new version already installed
  nispyi-2.4.0-f0
  ni4882betai-2.5.1-b1
  nipali-2.0.0-f1
But the error is still the same with gpibexplorer as well as with my applications. libnipalu.so still aborts ..
limit -c unlimited
Suse-havel:~ # gpibexplorer
Aborted (core dumped)
Suse-havel:~ # gdb /usr/local/bin/gpibexplorer core.4432
GNU gdb (GDB; openSUSE 11.1) 6.8.50.20081120-cvs
Copyright (C) 2008 Free Software Foundation, Inc.
License GPLv3+: GNU GPL version 3 or later <http://gnu.org/licenses/gpl.html>
This is free software: you are free to change and redistribute it.
There is NO WARRANTY, to the extent permitted by law.  Type "show copying"
and "show warranty" for details.
This GDB was configured as "i586-suse-linux".
For bug reporting instructions, please see:
<http://bugs.opensuse.org/>...
(no debugging symbols found)
warning: Can't read pathname for load map: Input/output error.
Reading symbols from /lib/libdl.so.2...(no debugging symbols found)...done.
Loaded symbols for /lib/libdl.so.2
Reading symbols from /lib/libpthread.so.0...(no debugging symbols found)...done.
Loaded symbols for /lib/libpthread.so.0
Reading symbols from /lib/libc.so.6...(no debugging symbols found)...done.
Loaded symbols for /lib/libc.so.6
Reading symbols from /lib/ld-linux.so.2...(no debugging symbols found)...done.
Loaded symbols for /lib/ld-linux.so.2
Reading symbols from /usr/local/lib/liblvrt.so.8.0...(no debugging symbols found)...done.
Loaded symbols for /usr/local/lib/liblvrt.so.8.0
Reading symbols from /usr/local/lib/linux/libOSMesa.so.4...(no debugging symbols found)...done.
Loaded symbols for /usr/local/lib/linux/libOSMesa.so.4
Reading symbols from /usr/X11R6/lib/libGL.so.1...(no debugging symbols found)...done.
Loaded symbols for /usr/X11R6/lib/libGL.so.1
Reading symbols from /usr/lib/libX11.so.6...(no debugging symbols found)...done.
Loaded symbols for /usr/lib/libX11.so.6
Reading symbols from /usr/lib/libXext.so.6...(no debugging symbols found)...done.
Loaded symbols for /usr/lib/libXext.so.6
Reading symbols from /lib/libm.so.6...(no debugging symbols found)...done.
Loaded symbols for /lib/libm.so.6
Reading symbols from /usr/X11R6/lib/libGLcore.so.1...(no debugging symbols found)...done.
Loaded symbols for /usr/X11R6/lib/libGLcore.so.1
Reading symbols from /usr/lib/tls/libnvidia-tls.so.1...(no debugging symbols found)...done.
Loaded symbols for /usr/lib/tls/libnvidia-tls.so.1
Reading symbols from /usr/lib/libxcb-xlib.so.0...(no debugging symbols found)...done.
Loaded symbols for /usr/lib/libxcb-xlib.so.0
Reading symbols from /usr/lib/libxcb.so.1...(no debugging symbols found)...done.
Loaded symbols for /usr/lib/libxcb.so.1
Reading symbols from /usr/lib/libXau.so.6...(no debugging symbols found)...done.
Loaded symbols for /usr/lib/libXau.so.6
Reading symbols from /usr/lib/libXcursor.so.1...(no debugging symbols found)...done.
Loaded symbols for /usr/lib/libXcursor.so.1
Reading symbols from /usr/lib/libXrender.so.1...(no debugging symbols found)...done.
Loaded symbols for /usr/lib/libXrender.so.1
Reading symbols from /usr/lib/libXfixes.so.3...(no debugging symbols found)...done.
Loaded symbols for /usr/lib/libXfixes.so.3
Reading symbols from /usr/lib/gconv/ISO8859-1.so...(no debugging symbols found)...done.
Loaded symbols for /usr/lib/gconv/ISO8859-1.so
Reading symbols from /usr/local/lib/LabVIEW-8.0/libnitaglv.so...(no debugging symbols found)...done.
Loaded symbols for /usr/local/lib/LabVIEW-8.0/libnitaglv.so
Reading symbols from /usr/local/lib/LabVIEW-8.0/liblkrealt.so...(no debugging symbols found)...done.
Loaded symbols for /usr/local/lib/LabVIEW-8.0/liblkrealt.so
Reading symbols from /usr/local/lib/LabVIEW-8.0/liblksec.so...(no debugging symbols found)...done.
Loaded symbols for /usr/local/lib/LabVIEW-8.0/liblksec.so
Reading symbols from /usr/local/lib/LabVIEW-8.0/liblksock.so...(no debugging symbols found)...done.
Loaded symbols for /usr/local/lib/LabVIEW-8.0/liblksock.so
Reading symbols from /usr/local/lib/LabVIEW-8.0/liblkdynam.so...(no debugging symbols found)...done.
Loaded symbols for /usr/local/lib/LabVIEW-8.0/liblkdynam.so
Reading symbols from /usr/local/lib/libNiSpyLog.so...(no debugging symbols found)...done.
Loaded symbols for /usr/local/lib/libNiSpyLog.so
Reading symbols from /lib/libgcc_s.so.1...(no debugging symbols found)...done.
Loaded symbols for /lib/libgcc_s.so.1
Reading symbols from /usr/local/lib/liblvgpibconf.so...(no debugging symbols found)...done.
Loaded symbols for /usr/local/lib/liblvgpibconf.so
Reading symbols from /usr/local/lib/libgpibconf.so.2...(no debugging symbols found)...done.
Loaded symbols for /usr/local/lib/libgpibconf.so.2
Reading symbols from /usr/local/lib/libnipalu.so.1...(no debugging symbols found)...done.
Loaded symbols for /usr/local/lib/libnipalu.so.1
Reading symbols from /lib/librt.so.1...(no debugging symbols found)...done.
Loaded symbols for /lib/librt.so.1
[New Thread 4436]
[New Thread 4442]
[New Thread 4439]
[New Thread 4438]
[New Thread 4441]
[New Thread 4440]
[New Thread 4437]
Core was generated by `gpibexplorer'.
Program terminated with signal 6, Aborted.
(gdb) bt
#0  0xffffe430 in __kernel_vsyscall ()
#1  0xb7e4e990 in raise () from /lib/libc.so.6
#2  0xb7e502c8 in abort () from /lib/libc.so.6
#3  0xb1593f03 in ?? () from /usr/local/lib/libnipalu.so.1
#4  0xb1593cde in ?? () from /usr/local/lib/libnipalu.so.1
#5  0xb1594305 in ?? () from /usr/local/lib/libnipalu.so.1
#6  0xb159435e in ?? () from /usr/local/lib/libnipalu.so.1
#7  0xb15f9b51 in ?? () from /usr/local/lib/libnipalu.so.1
#8  0xb159289e in ?? () from /usr/local/lib/libnipalu.so.1
#9  0xb7fc9db4 in ?? () from /lib/ld-linux.so.2
#10 0xb7fc9ee4 in ?? () from /lib/ld-linux.so.2
#11 0xb7fcdebb in ?? () from /lib/ld-linux.so.2
#12 0xb7fc99f6 in ?? () from /lib/ld-linux.so.2
#13 0xb7fcd66c in ?? () from /lib/ld-linux.so.2
#14 0xb7f9ac4f in ?? () from /lib/libdl.so.2
#15 0xb7fc99f6 in ?? () from /lib/ld-linux.so.2
#16 0xb7f9b11c in ?? () from /lib/libdl.so.2
#17 0xb7f9ab81 in dlopen () from /lib/libdl.so.2
So if anyone out there has a good idea, please help.
Best regards
(3,591 Views)
