Why does 24xx_Swp-V_Meas-I_gpib freeze just before completion?
Hello,  I have a Keithley 2400 and 2420 Source Meters.  I have recently installed Labview 8.6 and connect the multimeters (one at a time) with a GPIB_USB_HS adapter.  I have also downloaded and successfully used the offered 24xx_Swp-V_Meas-I_gpib.vi to sweep voltages and measure current.
My problem seems to arise if I use too many points or use a source delay anything close to a second?
Am I overloading some internal memory?  Or is there some timeout function in the block diagram that I can  increase?
Thanks for your help- Josh
(3,495 Views)
Here is the link to the user manual that might help
http://www.keithley.com/products/currentvoltage/?path=2400/Documents#6
(3,472 Views)
This is a very similar problem that I am running into also. I increase the Sour Delay past .680s and I get a GPIB read error, but the manual isnt exactly helping me with this situation.
I really think there is some timeout function that could be changed.
(3,430 Views)
Hi
What errormessage do you get, and which LabVIEW instrument driver do you use?
greetings from the Netherlands
(3,416 Views)
