Need an example for acquiring a waveform from Agilent E5071B
Dear all,
As a new user I need an example(s) to get on the right track for acquiring a waveform (or read an analyzied result) from Agilent E5071B. I've installed the driver -"agena".
Cheers
(4,522 Views)
There are several examples in the driver. Have you tried running any of them? They are on the Instrument I/O>Instrument Driver>AGENA>Example palette. if you did not know they were there, maybe you should start with the Instrument Driver Network and check the links on what a driver is and how to use one.
(4,521 Views)
Thanks Dennis, I've tried to run examples inclueded in the AGENA driver, which gives me a good understanding of how they work. What I'm really to achieve in my project is to capture the screen on the analyzer and display the waveform in a graph, I've observed those examples given in other oscilloscope drivers. So I wonder how I'm be able to read the set of data from the instrument rather than a value at a marker (1 or 2).
(4,457 Views)
It's been a while since I used it and I don't have the instrument now. Have you looked at the Read Data and Memory Array function?
(4,451 Views)
Accepted by polcid
I've succeeded in read data from 5071B with the rountine of "search bandwith", and also I found the application example inclueded in the instrument driver did not complete and would not read the data without setting tracking on.
Thanks Den.
(4,417 Views)
