New to GPIB and LV
Hello all,
I am very new to LV and GPIB stuff. I needed basic help for the same. I have to communicate with Agilent E34401 DMM,  E 3648A DC power supply.I have DC load Agilent N3300A. I started the Measurement and Intrumentation Explorer and could identify these instruments connect via GPIB. I also have a scope Tek's  TDS2014. I need to use these instruments to do power efficiency measurements using LV. like measuring input current/voltage output current/voltage. How do I do the same? I want to know how i can trigger these instruments and control them via LV. a step by step help would make me understand this system.
I also want to know do I need a DAQ card or GPIB can work to read voltage and current with the instruments.
I would greatly apprecite if someone can guide me in this.I am using the help from LV 8.2 and Measurement and Instrumentation explorer.
Thanks in advance.
RKD
(3,971 Views)
First, you don't need a DAQ board. All you need is the GPIB controller. The instruments take a measurement and return the results over the bus.
For the rest of your question, I would suggest you go to http://www.ni.com/devzone/idnet/ and learn something about LabVIEW and instrument drivers. All of your instruments have drivers available for them and that will make your life a lot easier. Most, if not all, of the drivers will include a high level example VI to get you started. Another thing that I recomend is that you study the instrument manuals and learn how you configure a measurement manually. If you get familiar with the instrument front panel controls, then it's easier to relate that to the remote control commands that the drivers will issue.
(3,968 Views)
Thank you Dennis. I will follow that. and if I need anything  iwill post it on this board. Its good to know that I dont need a DAQ card. I appreciate your help.
(3,964 Views)
You may also want to look at ni.com/icfundamentals.  This site is specifically designed for those people beginning instrument control
(3,955 Views)
Thanks, I was going through the same,
 I tried to communicate with E34401A and it gives me error I put  *IDN? query request, then did a write and a read and it gives me error on the dispaly of 34401, i am unable to comprehend it.
(3,950 Views)
If you put a query then u just have to read the data returned by the intstrument. Dont give again the write command.
Labview 8.2
Learner
(3,939 Views)
