Ni488.2 driver installation problem of vista 32 (TARGETDIR is undefined)
I have problems with installation of ni488.2 (Win32) Version 2.5 for Vista x86 driver.
The driver installation stops with message:
„TARGETDIR is undefined, the Directory table seems malformed. Abording..“
How I can installation the driver?
Thanks, Roland
(5,428 Views)
Hello Roland,
please download the gpib driver again (maybe a file is corrupt).
A cutomer get the same error under vista with LV 8.2.1 (see link: http://forums.ni.com/ni/board/message?board.id=170&message.id=243155&requireLogin=False)
For the driver download use the link (the 2.5 driver is the latest driver version):
http://digital.ni.com/softlib.nsf/websearch/cf109c216ef27ef38625722c0074a384
Please check also vista updates (MSI Installer).
Did you tried to install the driver on another vista pc?
Kind regards,
Elmar
(5,410 Views)
Hello Elmar,
the solution is:
installation as a new local user with admin rights and not as a „old“ domain user with admin rights.
Thanks, Roland
(5,401 Views)
Hello Roland,
thanks for the info.
Generally you need admin rights if you install NI Software.
Kind regards,
Elmar
(5,397 Views)
