Hello everyone,
I am having problems trying to comunicate with a temperature controller R/S (Advanced model - Cole-Parmer instruments 89000-15) using the labview's VIs.
When I try to comunicate with the controller by the hyperterminal, I can do it, and the device also gives me a response. The problem is that the Labview is not being able to make the controller recognize the code that is needed to be inserted. The code is the 02 hex (what in ASCII is a black smile face) T1XX (where XX are the commands given to the controller) and 0D hex (<CR>) . I do not know how to make the device understand these ASCII characters, using the LabView interface. I already tried some variations of these charcaters, but none of them worked. I also tried to get these characters from the hyperterminal files, which the Labview can recognize, but gives as answer another character that means that the command was invalid.
If anyone have any suggestion about this issue, I would be grateful.
Regards.
