PCI-6250 DIO card does not show up in MAX
I am currently trying to use MAX to test out an installed PCI-6250 card.   My software applications are using the card and returning data but when I try to manually view the incoming analog signal in MAX the device does not show up on the devices and interfaces list.  Does anyone know why it would not show up?  Thanks.
(2,941 Views)
What software are you using to return the data?  Also do you have the latest version of the DAQmx drivers installed?
(2,923 Views)
